TonVH1
Oct 28, 2012Aspirant
Accessing Tonido from anywhere
Installed Tonido on a Ultra 2. Also setup port 10001 to forward t o the NAS.Now when I do locally "//MyNasIP:10001" I can add shares and more. However when outside the localnetwork and do "https://...
Oct 28, 2012Guru - Experienced User
You need to forward the https port through your router as well. If the http port configured to 10001, you'd access via https://MyID.tonidoid.com:10001
