jmelvin
May 03, 2008Aspirant
Add Crashplan client
Have been testing Crashplan (http://www.crashplan.com) on my laptop - pretty slick. Crashplan has a Linux client, so I suppose someone (not me) could get it running on the readynas? Anyone tried...
evandro1
May 11, 2008Aspirant
dornquast wrote: Why shouldn't you run a java vm on it? I only spent a few hours but I didn't find any reason to not run Java on it. It doesn't need much CPU or memory .. and you can run it headless.
On the contrary, the JVM requires gobbles of memory and quite some computing power when first executing the application in order to compile it. It also takes up quite a bit of disk-space, so it's not a good idea to install it, if you must, in the same file-system as root.
HTH
