jmelvin
May 03, 2008Aspirant
Add Crashplan client
Have been testing Crashplan (http://www.crashplan.com) on my laptop - pretty slick. Crashplan has a Linux client, so I suppose someone (not me) could get it running on the readynas? Anyone tried...
fifer55
Feb 03, 2011Apprentice
super-poussin wrote: this is bad : And store datas in: /usr/local/var/crashplan
it can full the root
so if you accept you can create symlink to point somewhere else in /c/ to prevent such problem
Thanks super-poussin for your advice. I figured the back up going to usr folder was bad, but wanted to verify.
Does everything else look OK?
Also, it appears I can manually add a directory. So for data back up something like:
CrashPlan will install to: /usr/local/crashplan
And put links to binaries in: /usr/local/bin
And store datas in: /usr/local/var/crashplan change this to (/media/CrashPlanBACKUP)?
Your init.d dir is: /etc/init.d
Your current runlevel directory is: /etc/rc2.d
Everything else OK? I just don't know what everything else is, since I am not all familiar with Linux.
