jmelvin
May 03, 2008Aspirant
Add Crashplan client
Have been testing Crashplan (http://www.crashplan.com) on my laptop - pretty slick. Crashplan has a Linux client, so I suppose someone (not me) could get it running on the readynas? Anyone tried...
archey
Nov 26, 2011Aspirant
fs1011 wrote: works perfect for me.
However, the crashplan instruction for running the client from PC is really not need. Here is what I did and works perfectly (I did have some help from an IT geek at work:) :
- Access your NAS through SSH and go into the folder where CrashPlan is installed
- Edit (vi) conf/my.service.xml
- There's a line that says ServiceHost. Fill out the IP of your NAS (the one from your LAN like 192.168.1.2)
- Save the file and restart the CrashPlan service
- On your computer (the one you want to control your NAS backups from), look for a file called ui.properties in Program Files/CrashPlan
- Edit the file and uncomment the serviceHost line and modify 127.0.0.1 with the IP of your NAS (for instance 192.168.1.2).
Finally, open CrashPlan.
Thanks, this worked.
