zuki1919
Apr 02, 2020Aspirant
amule 1.0.3
Hello, for long time I was using amule by Poussin on my ReadyNAS RN102 with great satisfaction, and I was able to install it on newer firmware versione even if it was no more available on the cloud, ...
Apr 02, 2020Guru - Experienced User
zuki1919 wrote:
Hello, for long time I was using amule by Poussin on my ReadyNAS RN102 with great satisfaction, and I was able to install it on newer firmware versione even if it was no more available on the cloud, but now I lost the installer, does anybody have it sharable? Github cannot give it anymore...
Many thanks, zuki1919
Netgear found it was not compatible with OS 6.6.0 and later firmware. They archived it here: https://github.com/ReadyNAS/sdk/wiki/App-Archive
Personally I would trust them, and not attempt to install it on a NAS with up to date firmware. If you do attempt it, I suggest making a backup first.
zuki1919
Hello StephenB, many thanks for your kind answer, I know it's not compatible, but it seems to work...the archive you attached is no longer working trying to download the file, it gives accessing error. Do you know any other way to achieve the installing file?
Attached the error...
- StephenBApr 02, 2020Guru - Experienced User
Sorry, I don't. Perhaps JohnCM_S or Marc_V can sort this out.
- zuki1919Apr 02, 2020Aspirant
Nice to meet you StephenB, and many thanks for your kindness, hope they will have time to help me.
Kind regards, zuki1919
- JohnCM_SApr 02, 2020NETGEAR Employee Retired
Hi zuki1919,
I will have to check if we can do something about the download link but since it is a 3rd party app I cannot assure you anything.
