zuki1919
Apr 02, 2020Aspirant
amule 1.0.3
Hello, for long time I was using amule by Poussin on my ReadyNAS RN102 with great satisfaction, and I was able to install it on newer firmware versione even if it was no more available on the cloud, ...
zuki1919
Hello StephenB, many thanks for your kind answer, I know it's not compatible, but it seems to work...the archive you attached is no longer working trying to download the file, it gives accessing error. Do you know any other way to achieve the installing file?
Attached the error...
Apr 02, 2020Guru - Experienced User
Sorry, I don't. Perhaps JohnCM_S or Marc_V can sort this out.
- zuki1919Apr 02, 2020Aspirant
Nice to meet you StephenB, and many thanks for your kindness, hope they will have time to help me.
Kind regards, zuki1919
