StefanLund
Aug 03, 2009Follower
Application Initialization error
When I start ReadyNAS Remote I get error message "Application Initialization error" with buttons "Resatr Application" or "Quit". I have tried the following: * Reinstall the program. * XP computer a...
rrreed
Aug 24, 2009Aspirant
cap1 wrote: Remote does not use port 443 unless you specify in the setting.
If you reboot your PC, are you still getting this error?
Yes. I've rebooted, done uninstalls and reinstalls (latest release, v1.1.9), and still get the same error. I've tried both automatic and manual proxy configuration, too.
On a separate note, are there non-alphanumeric characters that Remote has problems with in passwords? I had to change from my original password (which the web site accepted) to a new one without any special characters because Remote kept telling me to enter my user ID and password even though the fields had been correctly filled.
