StefanLund
Aug 03, 2009Follower
Application Initialization error
When I start ReadyNAS Remote I get error message "Application Initialization error" with buttons "Resatr Application" or "Quit". I have tried the following: * Reinstall the program. * XP computer a...
rrreed
Sep 04, 2009Aspirant
Thanks to some work by cap1, ReadyNAS Remote is up and running for me at work :D . The problem was that my work PC is not configured to do DNS lookups, and relies on the proxy server to do them, while ReadyNAS Remote apparently is expecting the opposite. The work around was to make sure ReadyNAS Remote was correctly configured for the proxy server, and to add two lines to the C:\WINDOWS\system32\drivers\etc\hosts file (in Windows XP Pro, at least):
Update: It looks like it works, but since the iTunes library was created on a Mac, there's no iTunes Library.itl file in the share. Since that's the file the Windows version of iTunes is looking for, I'll have to see if I can export the library file at home, and reload it here next week.
207.211.82.213 remote2.readynas.comI've mapped a network drive to my iTunes library share in ReadyNAS Remote, and I'm seeing if iTunes here will accept the share as just another library. Will update again once I see how that works.
207.211.82.215 remote.readynas.com
