StefanLund
Aug 03, 2009Follower
Application Initialization error
When I start ReadyNAS Remote I get error message "Application Initialization error" with buttons "Resatr Application" or "Quit". I have tried the following: * Reinstall the program. * XP computer a...
parkerc
Sep 09, 2009Aspirant
Hi
I get the same error..
I'm trying to use the ReadyNas Remote on my work PC, which as you would expect from a legal firm is quite well locked down.
I've added the DNS entries to the LM host, but that has not helped and originally I was prompted about adding proxy details which I did (as best I can but now that prompt does not come up again and I can't find a way to configure the application - Anyone know where I should go ?
I can see my profile https://remote.readynas.com/login.jsp and login no problem, so I guess the browser can access the site, but the application keeps failing and giving me the Application Initialization error, with only the option to quit or restart, both of which do not help me troubleshoot any settings.. it would be good to see a step by step view so I can see where (exactly) it fails.
Any help would be appreciated..
Using WinXP, IE7
Using WinXP, IE7
