StefanLund
Aug 03, 2009Follower
Application Initialization error
When I start ReadyNAS Remote I get error message "Application Initialization error" with buttons "Resatr Application" or "Quit". I have tried the following: * Reinstall the program. * XP computer a...
n00blike
Sep 29, 2011Aspirant
I found a "work around"
Im running win7 ult. 64bit
I tried the readynas remote and the leaf network installs but none of them worked (kept getting the initialization error).
So I was talking to a friend when he mentioned virtualbox.
So i have virtualbox(free) running xp pro, ran the readynas remote and it works fine!
So if you don't want to dual boot just run virtual box, make an xp pro virtual machine and install ready nas.
You can set up a folder that shares files between your virtual box and your real OS.
https://www.virtualbox.org/
