azzid
Jul 07, 2012Aspirant
apt-get -f install
Today I got notice of the new firmware (4.1.9) and installed it on my ReadyNAS NV+. While fiddeling about with the machine I also took the time to install apt-get. When trying to install things ...
azzid
Jul 08, 2012Aspirant
Same result:
My sources.list is quite simple:
What bugs me is the samba-common dependency that keep appearing, shouldn't have anything to do with the particular installation. It appears every time I run apt-get.
# apt-get update && apt-get install build-essential
Hit http://archive.debian.org sarge/main Packages
Hit http://archive.debian.org sarge/main Release
Hit http://archive.debian.org sarge/contrib Packages
Hit http://archive.debian.org sarge/contrib Release
Hit http://archive.debian.org sarge/non-free Packages
Hit http://archive.debian.org sarge/non-free Release
Hit http://archive.debian.org sarge/main Sources
Hit http://archive.debian.org sarge/contrib Sources
Hit http://archive.debian.org sarge/non-free Sources
Hit http://www.readynas.com readynas/ Packages
Hit http://www.readynas.com readynas/ Release
Reading Package Lists... Done
Building Dependency Tree... Done
You might want to run `apt-get -f install' to correct these:
The following packages have unmet dependencies:
build-essential: Depends: libc6-dev but it is not going to be installed or
libc-dev
Depends: libc6-dev-sparc64 but it is not going to be installed
Depends: gcc (>= 3:3.3) but it is not going to be installed
Depends: g++ (>= 3:3.3) but it is not going to be installed
Depends: dpkg-dev (>= 1.4.1.19) but it is not going to be installed
smbclient: Depends: samba-common (= 3.0.37.netgear2) but 2:3.5.15-netgear1 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
# cat /etc/apt/sources.list
deb http://www.readynas.com/packages readynas/
deb http://archive.debian.org/debian sarge main contrib non-free
deb-src http://archive.debian.org/debian sarge main contrib non-free
