GarthS
Feb 18, 2018Aspirant
apt-get install libio-socket-ssl-perl fails
I am trying to carry out an apt-get update and apt-get install libio-socket-ssl-perl on my Readynas duo v2 which has 5.3.13 s/w. I have attached a word doc of the install log which shows the errors ...
Sandshark
Feb 18, 2018Sensei
Given that the Debian distro in the Duo V2 is so old, you need to update your repositories to go to the archives instead of the active ones. Change the existing ones in etc/apt/sources.list to be similar to:
deb http://archive.debian.org/debian/ lenny contrib main non-free
Note that this assumes you really are running a V2, which runs OS5.x (this can be confusing since Netgear used "V2" in two incompatible ways). If it's really a V1 (running OS4.1.x, then you need the etch repositories.
GarthS
I think I just replied to someone else so here's what I meant to send to you.
Re: apt-get install libio-socket-ssl-perl fails (NETGEAR Communities Subscription Update) v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} st1\:*{behavior:url(#default#ieooui) }
Hi, Thanks for your quick response. The NAS is running 5.3.13 s/w so Duo V2 is correct? Below is the Vi sources.list from my NAS. Should I add something to this list (and what) or edit one or all of the existing lines?
login as: root
[email protected]'s password:
Linux nas-BE-A4-89 2.6.31.8.duov2 #1 Thu Apr 18 18:24:47 HKT 2013 armv5tel GNU/Linux
Last login: Sun Feb 18 15:11:46 2018 from hp-g6-garth.home
root@nas-BE-A4-89:~# cd /etc/apt
root@nas-BE-A4-89:/etc/apt# vi sources.list
deb http://www.readynas.com/packages 5.3.13/
deb http://ftp.us.debian.org/debian/ squeeze main
deb-src http://ftp.us.debian.org/debian/ squeeze main
deb http://security.debian.org/ squeeze/updates main
deb-src http://security.debian.org/ squeeze/updates main
deb http://ftp.us.debian.org/debian/ squeeze-updates main
deb-src http://ftp.us.debian.org/debian/ squeeze-updates main
- sources.list 1/10 10%
