scep
Mar 25, 2008Aspirant
Bittorrent autolinker
This script allows you to automatically send torrent links to your Readynas, it will also show the status of the torrents that your readynas is tracking. Updated 6-12-09 Right Click menu adde...
Vatoe
Jul 20, 2009Aspirant
I just came across this - fantastic stuff! I couldn't find the little monitor for a while there, then I realised that I had changed tabs and that the monitor disappears if you do - which is unlike the other download monitor (download status bar).
Keep up the excellent work.
