Janti
Dec 05, 2011Aspirant
BitTorrent, how do I set it up and use it?
I have the BitTorrent addon, bur I cannot find any information on how to use it. Even the ReadyNAS manual doesn't give me any answer. I open the download manager, but I don't know what to do next. ...
Mar 07, 2012Guru - Experienced User
It depends on whether you have a Duo V1 or a V2. What firmware version is listed on the home page of Frontview?
Janti wrote: That was useful for me too, because I have had the same problem. I even contacted NETGEAR about it, but didn't get any answer.
But I still don't understand which file I should chose: X86, Sparc or Arm? I have the Duo system. I cannot find any instructions on how to install it either. Anybody knows?
Regards
Jan
