Ferdi1
Jul 14, 2013Aspirant
Change in IP adress
Hello, Recentley I had to change the internal IP-adress of my NAS from 192.168.0.100 to 192.168.2.100. Ever since apps (like sickbeard and coachpotato) are giving connection errors. I only changed ...
Jul 20, 2013Guru - Experienced User
If you log in with ssh, and enter
Do both resolve to IP addresses? (lolo.sickbeard.com should redirect to lolo.sickcache.com, which should give you 5 IP addresses).
If so, see if ping works:
Was this change in IP address because you changed to a new internet provider? Are you still using the same LAN/WiFi setup - if not, what changes did you make?
# host lolo.sickbeard.com
# host couchpota.to
# ping lolo.sickbeard.com
# ping couchpota.to
