Ferdi1
Jul 14, 2013Aspirant
Change in IP adress
Hello, Recentley I had to change the internal IP-adress of my NAS from 192.168.0.100 to 192.168.2.100. Ever since apps (like sickbeard and coachpotato) are giving connection errors. I only changed ...
Jul 24, 2013Guru - Experienced User
ok. It sounds like the sticking point is that you don't know how to log in with SSH. Is that correct?
Let's back up. Can you tell us why you needed to change the IP address in the first place?
Also, did you make any other changes in your network at that point? That is, a new router, or a new internet provider?
