Ferdi1
Jul 14, 2013Aspirant
Change in IP adress
Hello, Recentley I had to change the internal IP-adress of my NAS from 192.168.0.100 to 192.168.2.100. Ever since apps (like sickbeard and coachpotato) are giving connection errors. I only changed ...
Jul 24, 2013Guru - Experienced User
Ok.
Now try
If the ping works, it will repeat until you type ctrl-c
Now try
host google.com
ping 108.160.155.153
