Ferdi1
Jul 14, 2013Aspirant
Change in IP adress
Hello, Recentley I had to change the internal IP-adress of my NAS from 192.168.0.100 to 192.168.2.100. Ever since apps (like sickbeard and coachpotato) are giving connection errors. I only changed ...
Jul 24, 2013Guru - Experienced User
Ok. Did the host command work?
Ferdi wrote: It gives: "couldn't get adress for 'ping': not found
