Ferdi1
Jul 14, 2013Aspirant
Change in IP adress
Hello, Recentley I had to change the internal IP-adress of my NAS from 192.168.0.100 to 192.168.2.100. Ever since apps (like sickbeard and coachpotato) are giving connection errors. I only changed ...
Ferdi1
Jul 25, 2013Aspirant
StephenB wrote: Ok.
Now try
host google.com
ping 108.160.155.153
If the ping works, it will repeat until you type ctrl-c
Did both host and ping again.
Host: connection timed out
Ping: 16 packets transmitted, 0 received
