Ferdi1
Jul 14, 2013Aspirant
Change in IP adress
Hello, Recentley I had to change the internal IP-adress of my NAS from 192.168.0.100 to 192.168.2.100. Ever since apps (like sickbeard and coachpotato) are giving connection errors. I only changed ...
Jul 25, 2013Guru - Experienced User
ok.
Can you post the full ethernet configuration on the NAS? (gateway, IP, subnet mask, and DNS servers)?
also, did you try reconfiguring as DHCP?
