Ferdi1
Jul 14, 2013Aspirant
Change in IP adress
Hello, Recentley I had to change the internal IP-adress of my NAS from 192.168.0.100 to 192.168.2.100. Ever since apps (like sickbeard and coachpotato) are giving connection errors. I only changed ...
Ferdi1
Jul 25, 2013Aspirant
StephenB wrote: While there, try entering these ping commands and see if the PC gets a response: ping lolo.sickbeard.com
ping couchpota.to
ping google.com
ping 108.160.155.153
All of the pings respond
StephenB wrote: BTW, who is your ISP, and what model router are you using?
ISP is the dutch provider KPN. It's for TV, internet and telephone. It comes with the xperiabox as router
