Ferdi1
Jul 14, 2013Aspirant
Change in IP adress
Hello,
Recentley I had to change the internal IP-adress of my NAS from 192.168.0.100 to 192.168.2.100. Ever since apps (like sickbeard and coachpotato) are giving connection errors. I only changed the IP in the menu of the server, do I need to make changes in other locations aswell?
Ferdi
For example
Ferdi
For example
[hpotato.core.plugins.base] Failed opening url in CouchPotatoApi: https://couchpota.to/api/search/jack+the/ Traceback (most recent call last):
File "/usr/share/cpserver/couchpotato/core/plugins/base.py", line 148, in urlopen
response = urllib2.urlopen(request, timeout = timeout)
URLError: <urlopen error [Errno -2] Name or service not known>
2013-07-14 11:41:54.203820 SEARCHQUEUE-RSS-SEARCH :: Error loading Sick Beard Index URL: http://lolo.sickbeard.com/api?t=tvsearch&cat=5040%2C5030
2013-07-14 11:41:55.102853 CHECKVERSION :: Unable to contact github, can't check for update: IOError('socket error', gaierror(-2, 'Name or service not known'))
- vandermerweMasterOk.i think StephenB has helped you to find the problem.
Your PC and the NAS are on the same network using the same gateway yet you have set different gateways for each and different dns servers. This is why I asked you whether you had changed these in my first post.
The gateway cannot be 192.168.2.1 as you have stated that this is part of the dhcp pool.
The gateway address should be that of your device that is connected to the Internet or WAN. It looks like this is 192.168.2.254. The DNS servers addresses are there too, although you should be able to just enter ( in the readynas) your gateway address as the DNS server address. - Ferdi1AspirantAfter some testing with other adresses it seems to be working now.
Thx a lot - Ferdi1AspirantOnly now I have a new problem: sickbeard and sabnzb keep shutting down :(
Please start a new thread, with a new title.Ferdi wrote: Only now I have a new problem: sickbeard and sabnzb keep shutting down :(
