riplatt
May 29, 2012Aspirant
CouchPotato V2 (CouchPotatoServer)
- EtzAspirantBut ReadyNAS`es already have CouchPotato add-on?
- bbaraniecLuminaryV2 is key word here.
- EtzAspirant
bbaraniec wrote: V2 is key word here.
I must have missed somehow that V2 "thingy"...
:nashammer: - F_L_Tutor+1 for a V2 version for the X86 Ultra
- F_L_TutorAny news regarding V2?
I can read that V1 is no longer supported by the CP team so a V2 package would be very much appreciated - riplattAspirantI have got it running by backing up the old install from /c/.couchpotato to /c/.couchpotato_old then hit clone into /c/.couchpotato
Change the init.d/couchpotato to reflect the changes as per the download, the front view manage link is still broken but the start/stop scripts and updates work.
I don't know how to package this but if you need any help reply here and I'll answer what I can. - F_L_TutorHi,
I tried to do what you suggested but without success :(
I took a backup of my cp folder and then tried to install git-core using apt-get. But since I only got an old version using apt I couldn't download the CP2 git package. So I ended up downloading it on Windows and then copy it to my CouchPotato folder.
But I cant access the CP page on port 5000.
Tried to start it with "python CouchPotato.py", I can see that the process is running but I still cant access the web page.
What did you change in the init.d script? Since the folder and py script is named the same as CP version 1 I didnt know what to change...
Would it be possible for you to write more in detail on how you succeeded? - riplattAspirantTry port 5050
- F_L_TutorTHANKS!
totally missed that they switched port.
I also see that some parameters are change in the startup. - F_L_TutorBTW
How did you install GIT? If you used apt-get what are the sources you are using?
It seems I need a proper GIT installation to be able to auto update:
[potato.core._base.updater] Failed using GIT updater, running from source, you need to have GIT installed. GitCommandFailedException: Command 'log -1 --pretty=format:%at e1d7440b9d374de9f1866fab912d86d764a0339b' failed in /usr/share/couchpotato (128):
fatal: invalid --pretty format: format:%at
