riplatt
May 29, 2012Aspirant
CouchPotato V2 (CouchPotatoServer)
Would like this as a add-on -> http://github.com/RuudBurger/CouchPotatoServer Regards,
F_L_
Jul 30, 2012Tutor
Hi,
I tried to do what you suggested but without success :(
I took a backup of my cp folder and then tried to install git-core using apt-get. But since I only got an old version using apt I couldn't download the CP2 git package. So I ended up downloading it on Windows and then copy it to my CouchPotato folder.
But I cant access the CP page on port 5000.
Tried to start it with "python CouchPotato.py", I can see that the process is running but I still cant access the web page.
What did you change in the init.d script? Since the folder and py script is named the same as CP version 1 I didnt know what to change...
Would it be possible for you to write more in detail on how you succeeded?
