riplatt
May 29, 2012Aspirant
CouchPotato V2 (CouchPotatoServer)
Would like this as a add-on -> http://github.com/RuudBurger/CouchPotatoServer Regards,
F_L_
Jul 30, 2012Tutor
BTW
How did you install GIT? If you used apt-get what are the sources you are using?
It seems I need a proper GIT installation to be able to auto update:
[potato.core._base.updater] Failed using GIT updater, running from source, you need to have GIT installed. GitCommandFailedException: Command 'log -1 --pretty=format:%at e1d7440b9d374de9f1866fab912d86d764a0339b' failed in /usr/share/couchpotato (128):
fatal: invalid --pretty format: format:%at
