mfe-
Jun 22, 2024Tutor
Create two logical groups using Flex-RAID
Hi, I got two hard disc drives from different vendors with about 1TB and i do not want to mirror them but expand the available disc space. I do not want to group both discs into one logical volume ...
- Jun 22, 2024
mfe- wrote:
mdconfig -a new -m /dev/md3 -l 0 -c 64 -r /dev/hde1 -s 0
I'm working on a ReadyNAS duo v1 (however I can't find it in Associated Products)
You shouldn't be doing this, you should be creating a new volume using frontview. It'd be called "D".
See pages 20-21 here:
saudade
Jun 22, 2024Apprentice
The manuals for the Duo V1 are here:
https://www.netgear.com/support/product/rnd2000v1_(readynas_duo_v1/#docs
I also have a Duo V1 but have it in X-Raid with the 2 drives (2tb each) mirrored. X-Raid is the default.
When you did the initial setup, did you pick Flex-raid?
