mfe-
Jun 22, 2024Tutor
Create two logical groups using Flex-RAID
Hi, I got two hard disc drives from different vendors with about 1TB and i do not want to mirror them but expand the available disc space. I do not want to group both discs into one logical volume ...
- Jun 22, 2024
mfe- wrote:
mdconfig -a new -m /dev/md3 -l 0 -c 64 -r /dev/hde1 -s 0
I'm working on a ReadyNAS duo v1 (however I can't find it in Associated Products)
You shouldn't be doing this, you should be creating a new volume using frontview. It'd be called "D".
See pages 20-21 here:
mfe-
Jun 22, 2024Tutor
Yes, I picked Flex-RAID but second disc does not show up as allocated and neither can't I access it from a mount point. I didn't find a section in the manual which discusses separated logical groups with Flex-Raid
saudade
Jun 22, 2024Apprentice
I'm sure one of the Guru's will be along shortly. In the meantime, looks like you do that from within Frontview (the Webui). Page 20 lists the steps. If you already have a volume with the 1st disk, you use Frontview to create a new volume on the 2nd disk.
Just to be sure, what version of RAIDiator are you on? 4.1.16 is the last one published. Are you able to access the Admin page?
