eton
Apr 20, 2012Luminary
DDClient - by WhoCares - I hope this one will work
Finally a new dyn dns client, D(yn)D(ns)Client, thanks WhoCares:
viewtopic.php?f=47&t=62337
What are your experiences on this?
Hey Netgear, I can't understand why you don't have a dyn dns client built-in in FrontView - it amazes me. Let me remind you that it's 2012.
- DnsOMatic - didn't work for all hosts (as promised) and used dum constant updates and we got warnings from DynDNS etc.
DynDns - the old one, might work, never worked for me.
- etonLuminary
herko wrote: Thanks :-) vi worked, and it's installing ddclient now! Learning as we go :-)
That was good news. Glad it worked! - etonLuminaryWhoCares just updated DDClient Sparc to 3.8.2:
viewtopic.php?p=419078#p419078
Release notes:
http://sourceforge.net/p/ddclient/news/ ... -released/ - SandsharkSenseiLooking back at a few threads I've posted in in case they need updates.
If anyone is still looking for this add-on, it's at https://rnxtras.com/addons/ddclient-readynas-4-x86.
I also found out what the "skip=" is all about in the configuration. If the site you are using to determine your IP address returns anything other than just the address, it's used to tell DDClient what to skip to get to the address. The one in my example (second one that works) does return just the address, so the "skip=" is not necessary. - etonLuminaryUpdate. Now my ddclient.conf looks like this:
daemon=600
syslog=yes
pid=/var/run/ddclient.pid
ssl=yes
## ChangeIP
protocol=changeip, \
use=web, web=ip.changeip.com, \
server=nic.changeip.com, \
login=yourlogin, \
password='yourpass' \
yoursubdomain.domain.org
