EricNepean
Jul 15, 2012Aspirant
Disabling EnableRootSSH
I installed EnableRootSSH in my ReadNAS Duo v1 (4.1.9 firmware). Having finished with it, I now wish to disable ssh access, or at least ssh access to the to the root UserID. Is that possible and how?
gibxxi
Jul 16, 2012Guide
I think i read somewhere that re-installing the add-on again will disable root access. If that fails, or my information is incorrect, you could always re-install the current firmware your using over the top of the existing one, that ought to disable the rootssh access AFAIK.
