bnichols
Apr 25, 2009Guide
DNS-O-Matic add-on
Am just trying Super Poussin's new DNS-O-Matic add-on. Installed, disabled, modified the dnsomatic file and restarted the service. There doesn't seem to be a way to confirm that it's working. If I ...
dl78
Apr 26, 2009Aspirant
bnichols wrote: Am just trying Super Poussin's new DNS-O-Matic add-on. Installed, disabled, modified the dnsomatic file and restarted the service. There doesn't seem to be a way to confirm that it's working. If I log into my account on the dnsomatic website, it just sits there saying "Waiting for first update" for both my dyndns and opendns account. Any way to confirm its proper installation and usage?
Thanks!
PS I forgot to mention I installed the 1.1 version that was updated a few hours ago (from 1.0 early this morning).
I have the same issue:
DnsOMmatic_1.1 insttalled on my ReadyNAS duo, script "/c/addons-scripts/DnsOMatic/dnsomatic" modified with my DnsOMatic login & password (using editor under windows). After readyNAS reboot, DnsOMatic service is enabled but after 5 minutes or more, nothing updated on http://www.dnsomatic.com and message is "Waiting for first update".
It seems that ReadyNAS do not connect the dnsomatic website.
note: Can we change DnsOMatic frequency of update (like daemon=600 for the DynDNS add-on) ?
