bnichols
Apr 25, 2009Guide
DNS-O-Matic add-on
Am just trying Super Poussin's new DNS-O-Matic add-on. Installed, disabled, modified the dnsomatic file and restarted the service. There doesn't seem to be a way to confirm that it's working. If I ...
RWright
May 05, 2009Aspirant
super-poussin wrote: when you open a ssh conection you are in shell :)
to launch the script :
sh /c/addons-scripts/DnsOMatic/dnsomatic
to see the log :
tail -f /var/log/DNS-O-Matic.log
Hi super-poussin,
I cannot get this to work automatically. It updates correctly when I run it from a shell but not when I start the add-on as all I get in the log is the "NO Internet IP : exiting" message. I've added some extra log messages and the curl does not seem to return anything.
Can you suggest a way to fix this.
Thanks in advance.
