bnichols
Apr 25, 2009Guide
DNS-O-Matic add-on
Am just trying Super Poussin's new DNS-O-Matic add-on. Installed, disabled, modified the dnsomatic file and restarted the service. There doesn't seem to be a way to confirm that it's working. If I ...
dl78
May 09, 2009Aspirant
RWright wrote:
dl78 wrote: How do you open a ssh connection to run the script ?
Is there any specific add-on for the Duo to open the ssh ?
For ssh access:
http://www.readynas.com/?page_id=617
Check out the "Shell Access Patches" at the bottom.
Many thanks RWright for your help.
Now I was able to run the script "sh /c/addons-scripts/DnsOMatic/dnsomatic" and it works once each time run manually but the DynDNS IP is not changed.
I have similar log as you got:
Sat May 9 20:00:01 CEST 2009 NO Internet IP : exiting
Sat May 9 20:10:01 CEST 2009 NO Internet IP : exiting
Sat May 9 20:13:45 CEST 2009 : found: 82.235.xxx.xx cached IP:
Sat May 9 20:15:01 CEST 2009 NO Internet IP : exiting
Sat May 9 20:20:01 CEST 2009 NO Internet IP : exiting
Sat May 9 20:25:01 CEST 2009 NO Internet IP : exiting
