bnichols
Apr 25, 2009Guide
DNS-O-Matic add-on
Am just trying Super Poussin's new DNS-O-Matic add-on. Installed, disabled, modified the dnsomatic file and restarted the service. There doesn't seem to be a way to confirm that it's working. If I ...
super_poussin
May 26, 2009Virtuoso
it should update the IP , you shouldn't have to remove the file in /tmp
the remove I asked for is only to be sure we start with a good situation
