bnichols
Apr 25, 2009Guide
DNS-O-Matic add-on
Am just trying Super Poussin's new DNS-O-Matic add-on. Installed, disabled, modified the dnsomatic file and restarted the service. There doesn't seem to be a way to confirm that it's working. If I ...
super_poussin
Jun 08, 2009Virtuoso
ok perhaps it explain the curl difference :)
tansmission install curl on /usr/local/bin
but dnsomatic use a std curl debian package which seems to use a different path
problem is solved in last dnsomatic addon
for example :
for example :
IP=$(`wich curl` -s http://myip.dnsomatic.com/)
