bnichols
Apr 25, 2009Guide
DNS-O-Matic add-on
Am just trying Super Poussin's new DNS-O-Matic add-on. Installed, disabled, modified the dnsomatic file and restarted the service. There doesn't seem to be a way to confirm that it's working. If I ...
HereToday
Jul 12, 2009Aspirant
I need some assistance. I've fully read this thread twice and it seems that RWRight had the same issue as I have. Unfortunately, my permissions on the script are 777 so his fix won't work for me. I'm running v1.9 and can manually run the script with success. When I try to let it run on its own I always get the following:
XRAID:~# tail -f /var/log/DNS-O-Matic.log
Sun Jul 12 12:25:01 EDT 2009 : PB 12:25
Sun Jul 12 12:30:01 EDT 2009 : Running 0 12:30
Sun Jul 12 12:30:01 EDT 2009 : NO Internet IP : exiting
Sun Jul 12 12:30:01 EDT 2009 : found: cached IP:
When I run manually here is what I get:
XRAID:~# sh /c/addons-scripts/DnsOMatic/dnsomatic
Sun Jul 12 12:30:01 EDT 2009 : PB 12:30
Sun Jul 12 12:30:55 EDT 2009 : Running 0 12:30 96.228.246.16
Sun Jul 12 12:30:55 EDT 2009 : found: 96.228.246.16 cached IP:
Sun Jul 12 12:30:55 EDT 2009 : PB 12:30
Sun Jul 12 12:30:55 EDT 2009 : Return message of DNS-O-Matic : good 96.228.246.16
Note that the first four lines of the tail on the log are from the previous run. I've installed, disabled, edited the script or user/pass, then reenabled. Obviously it works when I do the sh command. It just doesn't want to work on its own. Any ideas?
Thanks for the help.
