bnichols
Apr 25, 2009Guide
DNS-O-Matic add-on
Am just trying Super Poussin's new DNS-O-Matic add-on. Installed, disabled, modified the dnsomatic file and restarted the service. There doesn't seem to be a way to confirm that it's working. If I ...
yachtman
Jul 12, 2009Aspirant
HereToday,
My mistake. Settings.json is used for Transmission (have too many config files in my head). The config file for DNS-O-Matic (which I think you already know) is:
#/c/addons-scripts/DnsOMatic/dnsomatic
Here is mine (unedited sections removed):
But make sure that the locations above are the actual locations for 'curl'. You can do a '#which curl' for it. I can't figure out why super-poussin's original code didn't work for me, but the mod made it goo.
titanium:/c/addons-scripts/DnsOMatic# cat dnsomatic
#!/bin/bash
HOSTNAME="all.dnsomatic.com"
USER="..."
PASS="..."
#IP=$(`which curl` -s http://myip.dnsomatic.com/)
IP=$(/usr/local/bin/curl -s http://myip.dnsomatic.com/)
#IP=$(curl -s http://myip.dk/ | egrep -m1 -o '[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}.[0-9]{1,3}')
RETURN=$(/usr/local/bin/curl -k -s https://${USER}:${PASS}@updates.dnsomatic.com/nic/update?hostname=${HOSTNAME}&myip=$IP&wildcard=NOCHG&mx=NOCHG&backmx=NOCHG)
