bnichols
Apr 25, 2009Guide
DNS-O-Matic add-on
Am just trying Super Poussin's new DNS-O-Matic add-on. Installed, disabled, modified the dnsomatic file and restarted the service. There doesn't seem to be a way to confirm that it's working. If I ...
HereToday
Jul 13, 2009Aspirant
yacthman,
That did the trick. I also ran the code you had and saw the same thing...the path wasn't getting passed to the variable even though the location was correct from the #which curl command.
super-poussin,
Great add-on. One which I will definitely upgrade to 2.0 once released. I also plan to donate. Thank you for your hard work on this one.
super-poussin,
