bnichols
Apr 25, 2009Guide
DNS-O-Matic add-on
Am just trying Super Poussin's new DNS-O-Matic add-on. Installed, disabled, modified the dnsomatic file and restarted the service. There doesn't seem to be a way to confirm that it's working. If I ...
secret_rivals
Sep 20, 2009Aspirant
xenozelda wrote: Hi, i've recently bought a ReadyNas Duo and started to install some add-ons
But i ran into problems getting DNS-o-matic to work. It keeps waiting for the first update.
This is what i've done.
Registered account at DNS-o-matic and setup DynDNS to test
Install the dns-o-matic via the Local Updater
Disabled the service
Change the user/password to the account i've registered with DNS-o-matic using notepad (or am i supposed to edit it another way)
Enable the service
Wait for 5mins, but nothing happened.
So i went to search around and found this thread. Is Shell access needed? I've installed PHP and shell access login on this DUO as well as transmission, does it matter? Can anyone help me on this?
Thank you in advance ^^
I have exactly this problem does anyone have a resolution to this?
