bnichols
Apr 25, 2009Guide
DNS-O-Matic add-on
Am just trying Super Poussin's new DNS-O-Matic add-on. Installed, disabled, modified the dnsomatic file and restarted the service. There doesn't seem to be a way to confirm that it's working. If I ...
secret_rivals
Sep 20, 2009Aspirant
I appear to be having the same problem with DNS-O-Matic that I had with the OpenDNS addon. OpenDNS isn't getting the IP updates and no logs are being created. Could this be a permission problem on the addons-config share? The folders within are created e.g. OpenDNS or DnsDnsOMatic but these folders aren't being populated with log files. I haven't tweaked the permissions on the addons-config share since it was created so it should have the default permissions associated with it. I have also updated the DNS-O-Matic addon to V2.1.
I have been trying to get OpenDNS to update for months now with both addons but no updates happen and no log files are created so I can't troubleshoot the problem. Has anyone else had the no log files problem when using either of these addons. I now have two seperate posts addressing this problem one for OpenDNS, the other for DNS-O-Matic. ANy suggestions would be welcomed.
Thanks.
Thanks.
