bnichols
Apr 25, 2009Guide
DNS-O-Matic add-on
Am just trying Super Poussin's new DNS-O-Matic add-on. Installed, disabled, modified the dnsomatic file and restarted the service. There doesn't seem to be a way to confirm that it's working. If I ...
mickyching
Nov 02, 2009Aspirant
Hi guys,
I've installed 1.50 and it still does not appear to be running.
It updates if I run the script manually but does not seem to run automatically. According to FrontView, the add-on is running but I have checked the logs and they are not being updated.
My understanding is that it should check every 5 minutes. Is this still the case ?
Can anyone suggest how I can confirm that the process is running and suggest anything else I can check.
Thanks in advance.
Thanks in advance.
