bnichols
Apr 25, 2009Guide
DNS-O-Matic add-on
Am just trying Super Poussin's new DNS-O-Matic add-on. Installed, disabled, modified the dnsomatic file and restarted the service. There doesn't seem to be a way to confirm that it's working. If I ...
ksaraf
Nov 05, 2009Aspirant
Ok, removed 2.6, deleted the addons-config dir, reboot, install 2.7, reboot
-it created the addons-config dir, again with a 6 character password.
-When I try to start or stop the DNSoMatic service, it tells me the same thing - serivce cannot be stopped, or service was already stopped/failed to start.
-Only When I remove the password from the addons-config dir can i get into it to edit the config file. :(
