bnichols
Apr 25, 2009Guide
DNS-O-Matic add-on
Am just trying Super Poussin's new DNS-O-Matic add-on. Installed, disabled, modified the dnsomatic file and restarted the service. There doesn't seem to be a way to confirm that it's working. If I ...
swmoeller
Oct 02, 2011Aspirant
Not sure, if it helps, but if I run
It seems to be, that the script never reaches the point, where it accesses the dnsomatic-site to update the IP. Reason: When I enter wrong credentials (in the script) for the site, it does not complain.
Any help pointing me into the right direction is highly appreciated!
Stefan
https://<username for dnsomatic>:<password for dnsomatic>@updates.dnsomatic.com/nic/update?hostname=<mydomain>.dyndnsXXX&myip=<current ISP-IP>&wildcard=NOCHG&mx=NOCHG&backmx=NOCHG)manually (copied from the script), it updates the IP as desired on dnydns.
Stefan
