bnichols
Apr 25, 2009Guide
DNS-O-Matic add-on
Am just trying Super Poussin's new DNS-O-Matic add-on. Installed, disabled, modified the dnsomatic file and restarted the service. There doesn't seem to be a way to confirm that it's working. If I ...
ElectroNick
Oct 29, 2011Aspirant
I too seem to have come up against the same problem as many on this thread.
I have a ReadyNas Duo
I have done all steps suggested needed to get DNSoMatic working but dont seem to get any updates registered on the DNSoMatic website.
Reading this thread I have installed the EnableSSH add-on and managed to logon using Putty. (Little tentative about this as a real Linux/Unix newbie and not wanting to cause further damage.)
I have tried to run the dnsomatic script directly using 'sh' command but nothing seems to happen and get the error message unexpected end of file line 62:
Also I can't find the log file in /var/log or the tmpfile in /tmp.
It would appear that even though the add-on seems to be running it is not executing properly.
I think I've reached the limit of my knowledge.
Can anyone suggest anything
Cheers
Cheers
