bnichols
Apr 25, 2009Guide
DNS-O-Matic add-on
Am just trying Super Poussin's new DNS-O-Matic add-on. Installed, disabled, modified the dnsomatic file and restarted the service. There doesn't seem to be a way to confirm that it's working. If I ...
sethcshort
Jul 16, 2013Aspirant
Dang, I was hoping there would be a solution posted.
I'm using the latest version of sparc DNS-O-Matic add-on, which calls itself v.2.0 (7-13-09).
I've put in all the information as requested (username and password), after first disabling the add-on of course.
Found the dnsomatic file in the addons-scripts share that appeared after restarting the ReadyNAS, and I edited it with notepad (Windows).
I've re-enabled the plugin, and the ReadyNAS log reflects that it's started up, but I left it overnight and there's no update in the log or on the DNS-O-Matic site.
Is this add-on still being supported? Or should I try to figure out a different solution?
Thanks,
Seth
Thanks,
Seth
