carl666
Sep 29, 2011Aspirant
downloading torrent to nas at work. controll it at home?
hi. :) when reading on NAS homepages i came to this: "Best of all, queuing of the torrents can be done over the web from a slower wireless laptop, but the actual downloading is done on the Read...
dbott67
Sep 29, 2011Guide
carl666 wrote: trying to acsess my nas from home.(the nas is at work)
when i write the ip in firefox and log in i just get the Share site up.
That's expected behaviour. If you try to access the NAS over http (port 80) or https (port 443) you will get the "Shares" window.
As noted above, in order to access Transmission, you need to specify the port:
http://ip.address:8181/ - Transmission Interface - requires add-on to be installed and appropriate ports forwarded on your router
If you want access to Frontview:
https://ip.address/admin - Frontview Admin Interface
If you want access to your shares over HTTP
http://ip.address/ - Shares
