Sleepstalker
Mar 17, 2009Aspirant
Dropbox ?
Dropbox is a very handy service for keeping files in sync across multiple computers and it support Windows, Mac, and Linux. I have only tested in Windows so far, but I use Linux as well and might use...
matgr
Oct 29, 2010Aspirant
I've found out after installing that If I run the below Dropbox syncs, until then it does not.
The Deamon does not seem to run at startup even though I have the script in place.
Any ideas?
su - dropbox -c "env LD_LIBRARY_PATH=/lib64:/lib:/usr/lib:/usr/local/lib .dropbox-dist/dropboxd &"
Any ideas?
