Sleepstalker
Mar 17, 2009Aspirant
Dropbox ?
Dropbox is a very handy service for keeping files in sync across multiple computers and it support Windows, Mac, and Linux. I have only tested in Windows so far, but I use Linux as well and might use...
WhoCares_
Oct 29, 2010Mentor
The ReadyNAS doesn't use (most of) the startup scripts at all. So you either patch it into readynas_startup (and loose the patch on the next upgrade of your firmware) or you find another way of starting it automatically.
-Stefan
-Stefan
