Sleepstalker
Mar 17, 2009Aspirant
Dropbox ?
Dropbox is a very handy service for keeping files in sync across multiple computers and it support Windows, Mac, and Linux. I have only tested in Windows so far, but I use Linux as well and might use...
boz0
Nov 03, 2010Aspirant
Can't remember exactly where the startup script is, for the sake of the example let's assume it is /etc/init.d/dropbox.
You just have to create a symbolic link in the /etc/rc2.d folder (you'll need root priviledges) :
The service will now restart automatically with your readynas. You can also start it manually if you don't want to restart the readynas at this time :
Also, please note that you will no longer see the little icons on your dropbox files (up-to-date or syncing), since the filesystem won't be a local filesystem on your computer(s).
ln -s /etc/init.d/dropbox /etc/rc2.d/S99dropbox
/etc/init.d/dropbox start
