Sleepstalker
Mar 17, 2009Aspirant
Dropbox ?
Dropbox is a very handy service for keeping files in sync across multiple computers and it support Windows, Mac, and Linux. I have only tested in Windows so far, but I use Linux as well and might use...
Madlener
Apr 26, 2011Aspirant
in /etc/inittab you can find that the default runlevel is "2"
so i used the following script you can find in :
http://forums.dropbox.com/topic.php?id=9454
and copied it to:
and then created this symbolic link to the second runlevel:
then dropbox started automatically on my NAS upon reboot
and copied it to:
/etc/init.d/dropbox
ln -s /etc/init.d/dropbox /etc/rc2.d/S99dropbox
