Sleepstalker
Mar 17, 2009Aspirant
Dropbox ?
Dropbox is a very handy service for keeping files in sync across multiple computers and it support Windows, Mac, and Linux. I have only tested in Windows so far, but I use Linux as well and might use...
bbaraniec
Aug 18, 2011Luminary
Following that instruction mentioned above I have only one question.
/c/dropbox should be folder to sync and /c/.dropbox should be folder with dropbox sources. I've started dropbox and linked it with my account.
Two issues thou:
1. /c/dropbox has another folder within called Dropbox where is all my stuff to sync. How to get rid off that another /Dropbox folder and simply sync to /c/dropbox?
2. /c/dropbox also has .dropbox folder with *.db and pid etc. How to move this to /c/.dropbox folder?
EDIT
Or maybe I should make /c/.dropbox home directory of dropbox user and mkae symbolic link /c/.dropbox/Dropbox to /c/Dropbox? So from Lan I could reach it \\nas\Dropbox. What would be better solution?
EDIT2:
Small workaround with samba shares did the trick ;)
Two issues thou:
EDIT
EDIT2:
